not for computer controlled vehicles
Car: 1985 Trans Am
Transmission: THM 700R
So debating on whether to buy remaned carb to tide me over till i get bigger engine.
Went to jegs and did vehicle search. came back with
http://www.jegs.com/i/JEGS/555/15805/10002/-1#
question is, at the very bottom it says not for computer controlled vehicles. I have searched and searched and every single carb says that. Aren't there any direct replacements? THat I dont have to remove ECM for?
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
Re: not for computer controlled vehicles
If you're talking about the computer controlled carby,here's a link.These are rebuilt very well.The cc carbs are dearer than the non cc.
http://www.smicarburetor.com/product...ID2/9/sfID3/34
Car: 1985 Trans Am
yeah but i only have a 305, i think that high of output will be too much for little block.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
What's wrong with your current carb setup? Or isn't there a current one.
Axle/Gears: Stock.
Car: 1985 Trans Am
Transmission: 4L80E/4L80E
It would be best to know why your carb isn't working properly before getting another one. Very often computer carbs aren't working due to no fault of the carb.
I don't know about Jegs, but if you do a vehicle-specific search on summitracing.com, they do have computer controlled carbs available. It will be a rebuilt, as no one makes new computer controlled carbs.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
