1982 camaro choke light
Old Jan 7, 2009 | 12:10 AM
palomarc's Avatar
my 82 camaro choke light keeps comming on , It blows the fuze and the temp and alt gauges quit working also ,any suggestions ?
Old Jan 7, 2009 | 12:54 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
You probably have a short in the choke circuit. Check the wire at the carb first, make sure it isn't melted or otherwise distressed and making contact with ground.
I've never seen a choke thermostat short out, but I suppose it's possible. Check it for proper resistance to ground.
Old Jan 15, 2009 | 03:12 PM
GICATA's Avatar
Car: '83 WS6 T/A 65,000 miles
Engine: 5.0L vin H stock, 406SBC right now
Axle/Gears: Corp. 3.73
Re: 1982 camaro choke light
Don't forget the "choke" circuit includes an oil pressure sensor that only closes the circuit once oil pressure is normal when diagnosing this problem.
Old Jan 15, 2009 | 03:56 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No it doesn't.
Old Jan 16, 2009 | 05:13 PM
GICATA's Avatar
Originally Posted by Apeiron
No it doesn't.
So does it function thru the Alt?
Old Jan 16, 2009 | 05:34 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes
Old Jan 17, 2009 | 02:03 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
1987 does run the choke circuit through a oil pressure switch. For some reason they completely redesigned the circuit that year. The '82-86 system uses the alternator.
Vintageracer
Jan 10, 2020 05:33 PM
TheJoeY88
Dec 31, 2016 07:30 PM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
