predator carb
Old Jan 16, 2009 | 09:07 AM
iroc a 86 berli's Avatar
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
predator carb
well i did a quick search on tgo, and didnt see anything about it. this is a question for the drag racers on here.
has anyone ran a predator carb on there built race engines?? here is a link to a sight that rebuilds them and sells them. personally i think they look pretty wicked. i have done a little reading on them and hear mixed feelings. mostly fanboyism. currently im running a holley 850 dbl pmp. this caught my eye cause it a venturi design from around 300 to 900 cfm, and doesnt over/under carb your engine.
http://carburetorsandmore.com/predator_carb.htm
Old Jan 16, 2009 | 12:45 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: predator carb
I remember seeing only one user who used one years ago. One of the biggest problems with them is the height. They also have problems metering cruise mixtures, so don't expect good mileage out of one.
A vacuum secondary like a VS Holley or demand secondary carb like a Quadrajet also has "variable CFM" and doesn't over or under carburate.
Old Jan 16, 2009 | 01:15 PM
Re: predator carb
i think it will fit under that hood, and with my cam, cruising is pretty much a joke. i get about 7mpgs if im lucky now, as for a vs holley or q jet, i dont think those routes are an option. i donno, maybe ill try one out. thanks for the reply.
Old Jan 16, 2009 | 01:21 PM
christian'sZ's Avatar
Re: predator carb
novelty POS!!! knew two guys that ran one . one ran like s**t; the other burnt to the ground. carb fire!
Old Jan 16, 2009 | 01:35 PM
Re: predator carb
lol, nevermind then.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
