300 bucks????
Car: 1984 camaro z28
Engine: L69 H.O
300 bucks????
Ok so I've finally saved up enough money to get around to fixing my super rich carb problem. I was going to just replace it but a new carb is 300 dollars
.So i guess I'm gonna get it rebuilt does anyone know where i can send it to get rebuilt for less than 300 bucks. If you have any information i appreciate it
Engine: L69 H.O
Re: 300 bucks????
well im only 17 and that's about the only part on a car i have no experience with and i don't wanna screw it up.
Car: 1991 Trans Am
Engine: 305tbi to 350 carb'd
Axle/Gears: Stock
Re: 300 bucks????
im sure it comes with instructions that how i was with my tbi but when there was instructions i was set and i did it.
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: 300 bucks????
I do it
I have a carb on ebay under the username green2005james
or you could send me your carb and 120 and I will make sure it comes to you dialed in
if there are any parts that need to be replaced I have enough to make several carbs.
my carbs also come with a warranty
call me at 618-201-7114
Engine: L69 H.O
Re: 300 bucks????
jamon8 sounds like a good deal nothing against you but before i send off my carb and half my paycheck is their anyone that can vouch that you wont rip me off. Nothing against you its just that Ive been ripped off before and don't want it to happen again
Transmission: 4L80E/4L80E
I did my first carb rebuild at 17. It was the WCFB on the '57. A lot more complicated than the CC q-jet.
Basically you follow the instructions in the rebuild kit.
Engine: L69 H.O
Re: 300 bucks????
awesome guess ill just do the rebuild myself then thanks for all of the advice guys
Engine: 350 tpi
Re: 300 bucks????
I dont want you to get ripped off either
give it a shot yourself, if you run into problems ask the guys on these boards
they are quite helpfull
one good idea I can give is take alot of pictures, I do this every time I am working on a unfamiliar engine.
it really helps with reassembly to know where every little piece goes
Engine: L69 H.O
Re: 300 bucks????
thanks for all the help guys im about to go to the parts store and see if they have the kit in stock thanks for all the help and ill keep you updated
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Engine: L69 H.O
Re: 300 bucks????
is their a trick to getting the top plate of the carb off ive removed all visible screws even the two small ones under the throttle blades but it still wont pop off i got the bottom plate to come off
Engine: L69 H.O
Re: 300 bucks????
ive almost got it done but i have a question on the gasket that goes between the main carb body and the top plate the hole for the plunger is too small for the plunger to fit through should i cut it to make it fit?
Engine: L69 H.O
Re: 300 bucks????
i thought thats what it was called but Im prob just dumb hang on ill post a picture
Engine: 383 Carb
Transmission: 4L60
Re: 300 bucks????
That's the mixture control solenoid. You should be able to enlarge the hole a little to fit it. The gasket was probably cut for an older non-computer Quadrajet that had the usual power piston instead.
Engine: L69 H.O
Re: 300 bucks????
i got it back together i feel really dumb i just had to install the gasket then put that piece in and it works perfect thanks for the help
Good to hear. A lot better than 300 bucks, wouldn't you say? Or, even $120.
Engine: L69 H.O
Re: 300 bucks????
yep 25 bucks and about an hour and a half of my time thanks for all of the help guys now to install the fuel pump.
Engine: L69 H.O
Re: 300 bucks????
got it started about 5 minutes ago and it idles at about 2000 and wont drop below it what did i screw up to make it do this there are no vacuum leaks
Car: '86 Trans Am
Car: '86 Trans Am
Re: 300 bucks????
It's a start, I doubt it's your problem but I know mine acts up every now and then. You can let it idle and romp on the gas all you want and the idle wont drop down. Then, drive 50 feet and the idle drops. It's really weird.
no green
Jan 9, 2016 09:22 PM
Royal_Z
Sep 30, 2015 08:45 PM
