is 600cfm big enough for 350ci
Old Jan 28, 2009 | 11:48 AM
mpb74's Avatar
Car: 1986 Iroc-Z
Engine: 355 Phase 2 Bowtie heads
Axle/Gears: 342
i have a slightly modified 350 with a holley 600. the car runs good but it feels like it has more to give. i have an edelbrock torqer 2 and i'm about to change it for a performer. can a 600 cfm give a 350 small block chevy enough fuel?
Old Jan 28, 2009 | 11:58 AM
travishenry's Avatar
Car: 1988 Z28 Camaro
Engine: TPI 350
Transmission: TH350
Axle/Gears: 3.73 10 bolt
Re: is 600cfm big enough for 350ci
i ran a 600 holley on my 88 z28 and i went 13.2 with it.
Old Jan 28, 2009 | 12:00 PM
atc3434's Avatar
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
It should be plenty for a mild build, you get into good heads/cam and it may become a limiting factor.
Old Jan 28, 2009 | 12:24 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
buy the performer rpm for one. If this is the single feed line holley 600, i would recommend locating a holley 650 double pumper and that will be a solid HP increase and fuel economy would be similar to a vacuum secondary carb if you keep your foot out of the secondaries.
Old Jan 28, 2009 | 02:45 PM
mpb74's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 342
i'm going to change the intake and up the jets, maybe that will give me what i want
Old Jan 28, 2009 | 04:00 PM
atc3434's Avatar
Car: 1986 Camaro SC
Whats your heads/cam and exhaust like?
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
3.8TransAM
Oct 1, 2015 07:47 PM
dusterbd
Sep 29, 2015 08:40 AM
