Vapor return on a manual fuel pump
Hello,
I 'm am a new member and I would like to ask a question about the vapor return line on a 1983 Camaro with a manual fuel pump. I would like to install a more GPH fuel pump but most after markets that I have seen do not have the vapor return line hook up. Can that line be removed and blocked off? I wanted to avoid installing a eletric fuel pump as the car is completed.
Has anyone else ran into this and if so what did you do.
Please let me know.
Please let me know.
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
It's not a vapor return line, it's a liquid return line. Helps reduce the potential for vapor lock by keeping fuel moving in the supply line.
Look at the Carter M6626. http://store.summitracing.com/partde...5&autoview=sku (ignore the picture - it has the same fittings as the stock pump) It's what I'm running, supplies my somewhat healthy 350 with ease.
92camaroJoe
Aug 13, 2015 06:07 AM
carburated, carter, fuel, fuelpump, gen, gph, hook, installation, instructions, line, m6626, manual, pump, return, vapor
