cc swap'd carb
Car: 1986 Pontiac T/A
Engine: 4brl 305
Axle/Gears: garbage
cc swap'd carb
ok guys, I got an 86 t/a 305 (lg4)
It does not have the orginal carb. I have an edelbrock. My question is how can I bypass the ccc?
I dont want the carb computer controlled.
How would I go about doing this.
Is it just a standard carb swap or is there more to it?
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: cc swap'd carb
remove the carb, replace with a non-cc carb, replace dist with a vaccum advance dist, hide wires so you can put back to stock later if you want.
Transmission: 4L80E/4L80E
If it's an Edelbrock carb, it already isn't computer controlled.
If you have the original computer controlled distributor, you need to replace it with a distributor with vacuum and mechanical advance.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: cc swap'd carb
..and provide alternate means of locking torque converter. Sticky at top of carb forum.
theshackle
Mar 5, 2017 06:37 PM
