TECH QUESTION ABOUT EDEBROCK CARB!!!!!!!!
Old Mar 25, 2009 | 08:34 PM
1985IrocZ's Avatar
Car: 1985 Z28
Hey everybody....quick question for you guys. I have an 85 Z28 with a 305 LG4, with Vortec heads. I just bought a brand new out of the box 600CFM Edelbrock carb. I've done the adjustment of the idle mix, and the idle RPM, but the car doesn't drive as well as it should. The rods and jets are the ones that came with the carb when I bought it. I know I am being very vague, but my question is the following:
For my application, what rod and jet size would be the most appropriate (part numbers are accepted)???????
THANKS FOR THE HELP!!!!
Old Mar 26, 2009 | 06:45 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: TECH QUESTION ABOUT EDEBROCK CARB!!!!!!!!
if you got the electric choke, order Edelbrock 1487, if you got the manual choke order 1479.
Old Mar 26, 2009 | 10:28 AM
1985IrocZ's Avatar
Car: 1985 Z28
I dont understand, why does the chokemake the part numbers for the rods different????? Also, as far as the jets are concerned, which size should I be using???
Old Mar 26, 2009 | 01:20 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
He just gave you the part # for a recalibration kit
http://www.jegs.com/i/Edelbrock/350/1487/10002/-1#
Check the sizes of what you have now and compare to what's in the kits.
With a kit, you can try a few different combinations to see how it works.
Old Mar 26, 2009 | 06:01 PM
csmith3's Avatar
Car: 70T/A, 87Formula, 02Hawk, 06 GTO
Engine: 400, 350, LS1, LS2
Transmission: M21, 700r4, T56, 4L65-E
Axle/Gears: 3:55, 2:77, 3:45, 3:46
You replaced your Q-Jet with an Edelbrock (Carter)? Do you still have the Q-Jet?
Old Mar 26, 2009 | 06:15 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by 1985IrocZ
I just bought a brand new out of the box 600CFM Edelbrock carb. I've done the adjustment of the idle mix, and the idle RPM, but the car doesn't drive as well as it should....
Assuming that your idle mixture was set properly with a vacuum gauge, I would look into your timing and advance. I wouldn't worry too much about the rod and jet sizes, as they should be very close to what a 305 would need out o the box, even with the vortec heads....
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Cleotiz
Jan 6, 2018 08:56 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
