my camaros running rich. help?
Old Apr 1, 2009 | 12:29 AM
aciddrop2804's Avatar
Car: 1984 camaro Z28
Engine: 5.0L H.O. L69
(just got it yesterday by the way, very happy to be a third gen camaro guy now!)
now onto business.
my 4bbl quadrajet is running rich. how do I set it so it isnt running so rich? i looked at the sticky but I need it to be explained in common terms cuz im a little slow. lol have never worked with carbs before but i would like to learn and idk anybody who knows that much about them so a little help would be appriciated.(im 18 and all my freinds drive fuel injected unfortunately for me) if you could be as specific as possible with things like the location of adjustment screws and things that would be great. thanks in advance.
Old Apr 1, 2009 | 10:31 AM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
Re: my camaros running rich. help?
First question- how do you know it's running rich, and is it across the rpm range? There are multiple fuel circuits in the carb which control fuel mixture at different throttle positions and engine loads. Does it seem to run rich at startup, and lean out os it gets warm? Does it bog down when at wide open throttle (WOT)? Read up on the quadrajet, if you are unlucky it is one of the electronic ones and these can be difficult to tune. You might consider an upgrade to another carb/intake which will net you more power and easier tunability. By most accounts, Holly and Edelbrock carbs are easier to work with and both will give you power gains, possably effiency gains as well.
Old Apr 1, 2009 | 12:06 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Check it with a WBO2 to confirm it's rich and by how much.
If it just smells rich, it might not be.
You need to eliminate ignition problems and misfires first.
If it's the carb, then check for fuel leaks before changing the jets.
Old Apr 1, 2009 | 12:34 PM
well i havent checked it with a volt meter or plugs or anything like that but the exhaust has a lot of moisture in it and smells like gas it alsmost seems like if i put a lighter to it it would shoot fire. it seems to idle rough at start up and then goes away after it warms up. could it possibly be the choke?
also,it does not bog a wot
Old Apr 1, 2009 | 01:49 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
How does it run when fully warmed up? Still rich?
The cold start rough running sounds like the choke pull-off ("vacuum break" in GM-speak) either not adjusted properly or not operating properly. Easy way to check that is, with the engine cold, remove the air cleaner and plug the vacuum nipple that the hose going to the air cleaner connects to. Open the throttle enough for the choke to fully close. Start the engine, the choke pull-off should pull "in" and slightly open the choke butterfly. If it doesn't open enough or opens too far, idle quality will suffer. As the engine continues to run and warm up, the choke butterfly should gradually fully open. If it does not, that's your rich condition.
If the choke is fully opening and it seems rich when fully warm, you might have a weak O2 sensor. Is the SES light coming on?
Old Apr 1, 2009 | 04:47 PM
ok. i will try that.
no, the light isnt on.
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
92camaroJoe
Aug 13, 2015 06:07 AM
