Fuel Regulator Problem
Old Apr 19, 2009 | 12:11 PM
ssjp1014's Avatar
I purchased a holley fuel regulator to put on my 91 firebird, i am running the electronic pump from the tank to the carb 350 i put in. Problem is, the regulator is not doing much at all to bring down the pressure the fuel comes out with. any help is appreciated.
Old Apr 19, 2009 | 12:30 PM
Windsma's Avatar
Car: 88 FIREbird
Engine: 305ci
Re: Fuel Regulator Problem
From racing use (wet nitrous) those holley style regulators dont work for HIGH to low pressure apps.
Old Apr 19, 2009 | 12:47 PM
ssjp1014's Avatar
yeah that is the reg. that i have. but still it just doesnt even stop the flow of fuel at all... i had another cheap one, and i thought that i just was broken.. but it still did the same thing at low psi. could the pump be to powerful?
Old Apr 19, 2009 | 02:55 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by ssjp1014
...i am running the electronic pump from the tank to the carb 350 i put in...
Do you mean the stock electric in-tank pump? If so, you don't want to be using that regulator. It is a dead-head type, and the stock type in-tank pump needs constant flow. Get a return style reg like the Mallory 4309.
FWIW, that Holley reg does fine on the '57 with the Aeromotive SS pump.
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
