What size carb to use on 396 stroker???
Car: 1987 Camaro Iroc-Z
Engine: small block chevy stroked
Looking to get a new carb and trying to figure out what cfm to get.If anyone can give me some good advise on one.It does see street and strip time.must have 4150 flange,no choke and machanical secondaries.I talked with holley and was told nothing smaller than a 950 HP,what do you think??
Engine specs:
396 C.I.D stroker
11.2:1 compression
Fully forged lightweight crank,h-beam rods,forged aluminum flat top pistons with valve reliefs
.635 lift .255 @.050 duration crane solid camshaft
7800 rpm valve float
profiler pro aluminum heads that flow 325 cfm @.700
9" 4000 stall
Edelbrock super victor intake manifold 4150 flange
Nitrous in the near future
Engine specs:
396 C.I.D stroker
11.2:1 compression
9" 4000 stall
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: What size carb to use on 396 stroker???
950hp would be fine
or
a quick fuel carb
or
pro systems carbs are really nice
or
a quick fuel carb
or
I can get a deal on a holley 1040 cfm carb,you think its to much???
Car: 85 camaro
Engine: sbc 400 .30 over
Transmission: 700r4 with bm shift kit, 2200 stall
Axle/Gears: 7.625 10 bolt posi
a holley 600 or 700 would do just fine
Transmission: 4L80E/4L80E
Assuming you don't want to be floating your valves and will be shifting more like 7500 RPMs, you'll need at least 850 CFM. 900 would be better.
1040 probably won't help you any over a 900 or 950. If you were running a dual plane intake, bigger can be better, but with single plane, extra flow capacity will just be wasted.
I agree with the Holley HP or QFT recommendations. I personally don't know anything about Pro Systems carbs, but don't doubt the recommendation.
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
My advise to you is to not base your carb purchase on internet reccomendations. Nothing against anyone but speaking to a rep from a good carb shop can net great results. Patrick at Pro systems carbs will build you a perfect carb. I have a demon and could do much better.
i called a few places today that build carbs,was told to get something between 950-1050 cfm.I was told the same by holley and quick fuel
TheTraut88
Sep 7, 2015 05:22 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
383, 396, block, build, carb, carbs, carburator, carburetor, chevy, hp, prosystems, recommendation, size, small, stroker
