replacing fuel pump
Old May 7, 2009 | 11:19 AM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
replacing fuel pump
I'm going to replace my rearend with one I'm rebuilding and I figure its a good time to drop the tank and replace the pump/sending unit....I'm thinking of dropping in a carbed 350 in the future so do I replace the pump with an origional or upgrade and add a regulator so I can still run my existing 305 TBI? Thanks
Old May 7, 2009 | 01:49 PM
MiScHiEf's Avatar
Car: 88 Formula
Engine: 305 TBI
Re: replacing fuel pump
Just the pump and sending unit would be fine.
a TPI fuel pump would be a good choice, since the original will be lacking when you upgrade to the 350. The stock regulator will keep it around 11-13 psi so you don't need to change that.
Old May 7, 2009 | 09:27 PM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
hi , i have a fuel pump question...i have a edelbrock 1405 carb on my 350 with stock fuel pump....does it need to have lower producing psi pump or fuel regulator to adjust the psi to the recommended 6 psi by edelbrock on their carbs?,.,,any sense to this?
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
justin57
Aug 20, 2015 07:05 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
92camaroJoe
Aug 13, 2015 06:07 AM
