Vac Sec Adjustment Help
Old May 18, 2009 | 07:31 PM
Cruzer Dood's Avatar
Car: Toyota FJ 40
Engine: 350 Chevy
Transmission: SM420
Axle/Gears: 3.70
Hi Guys, I don't have a 3rd Gen, BUT I do have a SBC in my 4WD ( Toyota ). I lurk here for the Chevy info. I put some spring loaded needle and seats in my 1850 Holley this wkend, and was trying to remember the info in the Holley Tuning sticky. I " think " I messed up with the adjustment on the secondary adj screw, trying to get it open a little, while trying to keep the primary transition slot like a little square box in shape. It idles at a high rpm, even with the adj screws on the primary side screwed in . How do I get back to a close to stock setting on the Vac Sec screw? Motor is a 350, Edelbrock EPS man, 600 Holley, CCx cam ( 210/218, .447/.462, 111LC ). Any help appreciated. Al
Old May 18, 2009 | 11:30 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Need a better understanding of what adjustment screws you're talking about.
Old May 19, 2009 | 04:10 AM
Car: Toyota FJ 40
Engine: 350 Chevy
Transmission: SM420
Axle/Gears: 3.70
Re: Vac Sec Adjustment Help
Sorry, I'm talking about the small one that you get to from the bottom of the carb, if you were holding it in your hands. Make sense? Thanks, Al
Old May 19, 2009 | 12:01 PM
Damon's Avatar
You DON'T set the secondary throttle plates to uncover any of the off-idle transition slot on the secondary bores. That type of "visual adjustment" only applies to the primary side throttles/bores.
Back the adjustment screw out until the secondary throttles are fully closed in their bores and then open again about 1/2 to 3/4 turn from there. You should see no secondary transition slot showing, but it should be reasonablye close to showing if you open the secondary throttles are opened slightly.
Old May 19, 2009 | 06:44 PM
Car: Toyota FJ 40
Engine: 350 Chevy
Transmission: SM420
Axle/Gears: 3.70
Thanks, that's what I was looking for. Tried the search, not much there using the terms I put in, and even bought a SA Holley book from Auto Zone. No luck. Many thanks, Al
Mark_ZZ3
May 24, 2018 01:02 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
Reid Fleming
Oct 10, 2015 09:56 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
