carb issues on 83
Old Jun 2, 2009 | 08:48 AM
83trans's Avatar
carb issues on 83
i just rebuilt my carburetor and when i tried to fire up the car to tune it shot a fire ball out of it. a friend help me get it running and now it runs smooth at idle but when you crack the throttle it shoots fire *****. if you roll on the throttle it runs fine untill about 1/2 throttle then it bogs down and will choke the car out. its a holley 4160 and quite old. any advice?
Old Jun 2, 2009 | 02:47 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Re: carb issues on 83
Did you set the float levels, induction backfire is most likely caused by extreme lean conditions.
Make sure the firing order and ignition timing is correct.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Sep 17, 2020 08:26 AM
Infested
May 22, 2018 11:56 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
