correct fuel pump setup in '87 lg4 with lt1 cam
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
I was reviewing stickys/posts before diving ahead with an lt1 cam install, but read a little closer and noticed the lt1 cam doesn't have lobe for a mechanical fuel pump. I've got a mechanical fuel pump on my stock 305 plus a stock electric fuel pump in the tank. Obviously, the fuel pump needs to be straight before proceeding with the cam. Think I will need a Mallory 4309, but what else am I going to have to do?
Transmission: 4L80E/4L80E
Re: correct fuel pump setup in '87 lg4 with lt1 cam
The stock in-tank electric fuel pump is a "pusher" pump, intended to push fuel to the inlet of the mechanical pump. It isn't intended to provide pressure.
A good in-tank replacement like a Walbro 255 with a 4309 reg would be a good system to supply a bunch of poneys.
Car: Pontiac Firebird ´87
Engine: L69 305
It's a Mallory return-style regulator. Necessary when using a high pressure EFI fuel pump to regulate down the the ~6PSI that a carb requires.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
I retained the in-tank and installed a 'holley' knockoff in-line pump near the rear tank (exhaust is welded in so dropping the tank would be an effort). The pump is designed for carb pressures, 7 psi I recall?, so I retained the stock plumbing to include the stock fuel pump mounted on the block. This allowed the mech pump, even though it's not pumping, to provide the means of fuel return.
Verified that I was getting adequate pressure and flow at the carb and that fuel was flowing through the return line. This setup saved the stock plumbing up front and the $ on a return style regulator.
Downside is the mech pump still absorbs engine heat and the fuel can boil back when it heat soaks. Fuel running through it while running keeps it cool enough then. This could likely be worse if I were relying on the mech pump alone, though.
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
gm still makes a "corvette" in tank fuel pump that came with the old "H.O. 350 kit" its like 77$ shipped i think i have to see if i can find the PN its what i was gonna do if i dont have enough PSi at the carb
heres the PN 25116163 and a link where i found the details of the kit http://www.camarotech.com/engine-ZZ3.html
i figured it was easier this way and i like to keep it simple, but im sure the other methods will work well also
http://www.gmpartsdirect.com/results.cfm <<---- 60$ plus shipping just put that part number in the search engine... ill be using this and a cheap holley regulator with gauge if my intak doesnt put out enough at the carb
92camaroJoe
Aug 13, 2015 06:07 AM
for the suggestion!
