Fuel problems
Old Jun 16, 2009 | 06:30 PM
ssman9's Avatar
Car: 1992 Camaro RS
Fuel problems
I converted from tbi to carb on my 92 rs. I am still using the factory pump and using a mallory fpr. My problem is that when I went to adjust the pressure on the fpr, before I could get a good reading to where the pressure is sitting, fuel began coming out of the vent tubes of the carb.
I haven't started the car, the carb is a holley street avenger 670 (used ... hopefully the problem), and the pump is still the stock unit.
Any suggestions.
Mike
Old Jun 17, 2009 | 05:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You either had too much pressure for the floats to shut off the flow, or the needle/seats are not closing properly for one reason or another.
Old Jun 17, 2009 | 08:41 PM
ssman9's Avatar
Car: 1992 Camaro RS
Re: Fuel problems
I think part of it was the floats were stuck. I also pulled out the float adjuments pins and taped on the blowls. Now I was able to build pressure but only to about 3 lbs. I don't think it is a problem though my return line is leaking along with another fitting. Once I get them fixed I should be ok.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
