CC Q rebuild feature in CarCraft
Old Jun 19, 2009 | 11:40 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Just got the Aug. '09 issue, found a short article on them covering Sean Murphy redoing the QJ from '85 Monte L69. SMI shared a couple of "secrets".
Old Jun 19, 2009 | 07:19 PM
DoubleV's Avatar
Re: CC Q rebuild feature in CarCraft
Care to share what these secrets are?
Old Jun 20, 2009 | 09:15 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
I found it interesting that in the article they recommended SMI as a ccc-qjet rebuilder yet later in the 'What's your problem?" tech section they recommend Jet Performance for the ccc-qjet. Both by Jeff Smith. Can't make up his mind I reckon.
Overall it was pretty weak.
Old Jun 23, 2009 | 04:47 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I just picked up the magazine myself.
They mentioned drilling the main air bleeds I believe, and the choke pulloff. They didn't get into the specifics on HOW you do it, since it's not just a matter of pulling out your drill... More magazine crap showing a shiny picture and vaguely describing a modification for more power - just enough info to get you in trouble, or phoning a pro to do it for you.... yay for Car Craft....
Pick up the book by Doug Roe if you want the real info...
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
bjpotter
Oct 2, 2015 09:12 AM
hartsmike
Oct 2, 2015 07:11 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
