fuel sender question....
Old Jun 21, 2009 | 08:25 PM
IEatRice4dinner's Avatar
Car: IROC-Z
Engine: L98 350/ 5.7L
I will be running an inline pump and wont be using the stock tpi in tank pump anymore.
I decided to just modify a stock sending unit Name:  IMG_4197.jpg
I used a brass compression fitting with brass inlet tube. I also plan on brazing the fitting together so it wont loosen up.
Will that work out ok?
Old Jun 22, 2009 | 01:27 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I wouldn't bother brazing the fittings.
You need a pick-up sock, like the sticky in the top section of this forum describes. https://www.thirdgen.org/forums/carb...nk-pickup.html
Old Jun 22, 2009 | 02:03 PM
Car: IROC-Z
Re: fuel sender question....
i do have a sock
will galvanic corrosion be a big issue?
Old Jun 22, 2009 | 05:48 PM
five7kid's Avatar
No. The gas tank is a reasonably inert environment as long as you don't have water sitting in it.
Old Jun 22, 2009 | 09:22 PM
Car: IROC-Z
thanks for the info man!
Hellbillydeluxe
Sep 22, 2015 09:58 PM
NBrehm
Aug 25, 2015 11:49 PM
justin57
Aug 20, 2015 07:05 PM
355sbcTPI
Aug 19, 2015 04:38 PM
