carb problems
Old Jun 27, 2009 | 05:40 PM
91 camaro 383's Avatar
Car: 91 Camaro LS1
Axle/Gears: 9" 4.11
carb problems
i dont know a whole lot about carburetors but i recently converted mine to e 85 and hooked it up today primed the fuel pump and gas started coming out of the vent on the front of the carb main body and is just pouring into the carb on the otherside can anyone help me out here im thinking its the floats but honestly i dont know how to preset them after the conversion thanks
Old Jul 6, 2009 | 04:47 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You don't have to change the float settings just for E85.
Can we assume this is a Holley with externally-adjustable floats?
Start with the floats set low, and adjust them up with fuel being supplied to the carb (if you have to run the engine to adjust the floats, that may make it a little more complicated).
Old Jul 19, 2009 | 01:26 PM
ScottyRock's Avatar
Car: 92 L98 Z28 Heritage Hard Top
Engine: L98 350 w/ HSR,24lbs inj,AFPR
Transmission: TCI Super Street Fighter W/3300 sta
Axle/Gears: 3.73 Detriot NoSpin,LPW cover
Re: carb problems
The floats, sounds like you need to adjust them down a hair..Been doing a lot of looking around on the net about e85 and am thinking about doing it, look to raceone85.com for help. Good Luck
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
theurge
Aug 21, 2015 12:46 PM
