Rebuilt E4ME issues :x
Old Jul 2, 2009 | 08:04 PM
BahN's Avatar
Car: 1987 Trans AM
Engine: Twin Turbo 6.0 LS2
hey guys, I just strapped on a rebuilt E4ME from national carburetors, thing looks great, fired up just fine. The problem is, it dosnt see like the car has as much power as it use to. I adjusted the idle, and got that nicley sitting at 800rpm (smoothest). I have a cheap narrow band A/F gauge that i used to kinda get an "idea" for what it was doing (i know a narrow band isnt a tuning tool).
Now the problem, it's running rich i believe. If you floor the car to 5.5k and let off, it'll backfire. I checked TPS voltage, and it's a tad high. 0.61v at idle, should be 0.50 according to my manual. Would that really make that big of a difference? Before i replaced the carb, i ran my old one without the TPS even plugged in (it was shot), and it never backfired.
How do i adjust A/F at WOT/Any throttle at all?
All i can see are my idle rev adjustment, and i have two idle rich/lean screws on the bottom front of the carb, one on each side.
Any ideas? Thanks guy!
Old Jul 2, 2009 | 08:42 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Rebuilt E4ME issues :x
TPS voltage difference that small won't make much difference. The carb likely needs to be adjusted using a dwell meter or scan tool for proper IAB/dwell setting. There's some stickies on top that explain much of that. If you've got a dwell meter, or can get one, I can help walk you through it.
WOT is controlled primarily by the secondary rods/hangers and the air valve. There's a tech article here that provides some info.
Cornholio7979
Sep 20, 2018 02:31 AM
Americanmouse
Sep 7, 2015 12:10 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
mdtoren
Aug 23, 2015 12:52 PM
crazynights
Aug 21, 2015 06:53 AM
