Edelbrock 1406 Carb, High Idle at Startup
Old Jul 6, 2009 | 02:24 PM
sorch60's Avatar
I put an Edelbrock 1406 Carb on my L69 and when i start it up first thing in the morning/day the idle shoots up to about 2200 RPM. I can kick it down by just tapping the throttle, then once it's warmed up it starts up fine every time. Does anyone have a suggestion on what I should be looking for to resolve this? Before I modded the engine it used to start up to about 1400 RPM and kick down on its own, with the Q-Jet. Any ideas?
Adam
Old Jul 6, 2009 | 05:38 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Sounds like it's operating properly. You're supposed to have to tap the accelerator after initial start up to drop down from the highest idle speed.
Out of curiosity, why did you take off the q-jet? And, what distributor are you using?
Old Jul 6, 2009 | 08:00 PM
sorch60's Avatar
Re: Edelbrock 1406 Carb, High Idle at Startup
I'm running an MSD 6AL Ignition Box, MSD Coil, and MSD mechanical advance distributor. I capped off the front vacuum ports on the new carb, and hooked up the electric choke. The Q-Jet needed to be rebuilt anyway and I was doing the ignition, cam, and heads so I went for the carb and intake as well. Next up, headers.
Old Jul 7, 2009 | 09:47 AM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
sounds like it's working fine..you can always turn down the hi-idle screw to bring it down from 2200 rpm to what you like.
Old Jul 7, 2009 | 12:39 PM
sorch60's Avatar
I'm actually going to give that a shot. I have the normal idle set to about 800 RPM so I'm going to bring that down to 600 RPM then adjust the fast idle (hi-idle) down to about 1500-1600 RPM or so. Thanks for the info.
Old Jul 7, 2009 | 01:24 PM
mooch1's Avatar
Transmission: T5 WC
you can leave the normal idle at 800 rpm or so and try lowering the fast idle first...then see how it is and take it from there,
theshackle
Sep 17, 2020 08:26 AM
bamaboy0323
Sep 3, 2015 06:07 AM
86IROC112
Aug 17, 2015 02:00 PM
matthew911
Aug 12, 2015 09:38 AM
