91 Z28 TPI to carb... water neck and upper rad hose?
Car: Bone stock 1989 Iroc T-Top,1991 Z28
Engine: 5.7, Carbed 383
Transmission: 700r4, T-56
What water neck(thermostat housing) and upper radiator hose are you guys using? I read something about an upper hose from an 84? What make/model/engine? I have an upper hose from a 91 TBI car however the aftermarket water neck is too large for the hose.
Thanks.
Thanks.
Transmission: 4L80E/4L80E
A simple angled thermostat housing should work.
'82-'87 carb'd 305 should all use the same upper radiator hose.
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Sanjay
Aug 12, 2015 03:41 PM
