starting problem
Car: 1984 Trans am
Engine: V8
starting problem
yesterday i went out cruising in my 84 trans am and it started up right away three straight times. but later on that night when i was about to come back home it just cranked and i had to crank it ablut 4 time four it to start. what can be the problem? the starter? or does the carburetor need cleaning?
Transmission: 4L80E/4L80E
Was the engine turning over slowly when the starter was engaged, or was that normal?
Are we talking about a stock q-jet or something else?
Do you know if the choke is operating correctly?
How old are the plugs, plug wires, cap, and rotor?
92camaroJoe
Aug 13, 2015 06:07 AM
