Getting the carb ich
Old Aug 15, 2009 | 11:42 PM
Black Z28's Avatar
Car: '88 Iroc-Z z28 Camaro
Engine: Carb 355
Transmission: t5 5-speed
Axle/Gears: 4.11
Ive been wanting to swap over my tpi setup to a carb setup soo badly for quit some time now. my question is that do i have to have my electric fuel pump wit a regulator or can i run a mechanical pump and get rid of my electric in take one? i got a '69 chevy block under the hood so idk if that means anything special, i kno some newer blocks have the oil cooler lines but i dont.
Old Aug 16, 2009 | 05:30 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Getting the carb ich
You can do it either way. Using a mechanical pump will require dropping the tank, removing the electric pump, and installing a carb pickup line, but using the electric pump will require a $80 RETURN STYLE fuel pressure regulator such as the Mallory 4309 - owners choice.
Old Aug 16, 2009 | 07:04 PM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
Ok cool well i think i'll go wit the regulator, i dropped the tank once and aint gonna do it again. wat psi should the regulator be set at?
Old Aug 16, 2009 | 07:09 PM
Car: 1992 RS
Engine: Carbed 350
5-7 psi for carb. If you get the mallory, do not hook up a vacuum line to it - it makes tuning impossible - it's strictly for a blower or something.
Old Aug 16, 2009 | 07:13 PM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
Ok thanks for the info. How would i wire up the fuel pump relay and all tht good stuff when im taking out the harness and everything?
Old Aug 17, 2009 | 07:46 AM
Formula_Wolf's Avatar
Car: 1989 Firebird Formula
Engine: 305 Road Demon 525
Transmission: 700 R4
If I were to do mine again... I would have got the regulator and used the stock electric fuel pump to avoid the need to re route fuel lines and mount a new pump. Also! I dont think I would have went for the carb with the vacuum secondaries or electric choke. These two features seem to cause me nothing but prooooblems. I like the simple stuff, less things to go wrong.
Old Aug 17, 2009 | 10:01 AM
Car: 1992 RS
Engine: Carbed 350
IIRC you are the one with the Painless wiring harness and issues, right? You can put a relay under hood, with one side going to pump, other side going to battery, then add a ground and a hot-in-run on the other prongs - thus when key is turned on, relay gets energized, sending battery poer to the pump, and pump only gets juice whrn key is on.
Old Aug 18, 2009 | 11:19 AM
Black Z28's Avatar
Engine: Carb 355
Axle/Gears: 4.11
Wow tht seems pretty dang simple, gonna have to do some research an hunt down the rite wires for the pump and everything
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
