weber carb question
weber carb question
i bought a weber carb but am having trouble figuring out what model it is and how to hook it up. i have a 88 irock tpi 350 that i made carburated. i dont know how to run the fuel lines and the throttle and tranny cable to the carb, or verifing what weber i have if i need to rebuild it.
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Re: weber carb question
How many CFM is it supposed to flow?
The only intake I can immediately think of that mounts a weber to a SBC is an Offy cross ram... and you need three webers to use that.
Do you have it mounted to the engine yet?
Can you post pics of it?
i have it connected to an edelbrock intake and bolts up. i have some pictures of it off the engine but it did bolt up just fine to it. let me see if i can get pictures loaded up of it.
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
That type of weber... what was I thinking... I believe they are mostly the same as edelbrock and carter carbs, which I know are commonly put in our cars.
ok thanks im glad its commonly put in the cars. however i still need to konw what i am type i have if i need parts to rebuild and how to hook it up. where do the fuel in adn out lines run from my pressure regulator? thanks
LOL im sorry man i feel like a jerk squirted one. i just bought a edelbrock 1405- 600 cfm, manual choke or at least what i think is one since you told me that mine was that and the one i just bought looks like a spitting image of it
got this pig for 30 bucks tooJoined: Aug 2006
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
its really too small for your app, sell it
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
I am pretty unfamiliar with edelbrocks, but 600 cfm is to small for even the mildest of 350's. At least you can make the car run with that carb on it.
crap no way its too small. darn it because i have built it a little. so what would you suggest carbs wise? i have it bored .30 over, a 262/.420 cam, long tube headers, 202 heads thats the most of it performance wise. so what about a holly 750 double pumper would that one be better? i mean i guess it dont matter for me since i am selling the car as soon as i get the engine finished and running.
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
If you just want to get it running to sell it, you might as well put the edelbrock on.
It will run, but it won't perform as well as a larger carb would. Since you probably have an auto trans, stay away from a double pumper.
Transmission: 4L80E/4L80E
Weber makes Edelbrock's carbs. Somebody popped the Edelbrock nameplate off of yours.
84z96L31vortec
Aug 20, 2017 12:16 AM
