help carb problems
Old Sep 27, 2009 | 01:38 AM
halenutz's Avatar
Car: 87 camaro t-tops
Engine: 77 350 corvette stingray
Transmission: th350
Axle/Gears: stock 87
help carb problems
i got this quadrajet off my buddie to run while i try to rebuild my carter it has a electronic plug on the top of it it is off a 80s firbird that ran well anyway do i have to hook up this plug and what is it for???? if it cant run without or if i might have a plug hanging in there that will run it there are a few it had a 2.8 multi now has a 77 350 hei vac advance
Old Sep 28, 2009 | 05:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There is nothing in your car that you can plug into that carb. You need a computer-controlled carburetor harness and ECM, along with the distributor and all sensors, to get that carb to run properly.
Old Sep 28, 2009 | 05:46 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: help carb problems
X2. Get a Holley don't bother rebuilding the carter.
Old Sep 28, 2009 | 08:30 PM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
Why not? I know many people who run Edelbrock carbs, which are Carter AFB's. Including myself, and it's been great. I've never run a Holley, but I don't tell anyone not to, they may prefer those over the Edelbrocks.
Have you ever run a Carter or Edelbrock?
Old Sep 28, 2009 | 08:34 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Holley til the day I die.
Old Sep 29, 2009 | 07:07 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
If the quadrajet only has a plug on top and does NOT have the three wire TPS plug on the left/front then it's a mechanical qjet and you can use it. Some mechanical models came with a two wire fuel enrichment solenoid that has a plug similar to the MCS plug on top of ccc-qjets. Odds are against this though. The ccc-qjet appeared on fbodys by at least '81 maybe earlier.
Old Sep 30, 2009 | 08:10 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Yes on at least 6 different cars, they came with them I didn't put them on there. The Holleys I replaced them with were always a HUGE improvement. In a 4 barrel carb Holley and Holley clones are head and shoulders above the rest.
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
theurge
Aug 21, 2015 12:46 PM
