Factory TBI Pump, return style regulator, pump life expectancy?
Old Oct 11, 2009 | 07:52 PM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
I've read in a couple places that even with a diaphragm-style (Mallory, Holley etc) return regulator, the factory pump will eventually burn out.
Any input on this? I'd rather not have to deal with that sort of thing if it's avoidable.
Old Oct 11, 2009 | 08:02 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Factory TBI Pump, return style regulator, pump life expectancy?
There's no real rhyme or reason - the pumps run, then they don't - it's a fact of life - usually no warning or signs of it - it just dies. I replaced my pump when I swapped to carb, and I'm using the Mallory reg, and 3 years later no issues. I used a CarQuest pump.
Old Oct 11, 2009 | 10:32 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
I used a TBI pump when I went carb'd with a Jegs Billet non-return regulator. It can handle up to 20 psi of inlet psi. This pump has been in a few years and it was used when I put it in. No problems and Im also using the same pump to run my nitrous.
Old Oct 12, 2009 | 11:26 AM
Pre-Tuner's Avatar
Car: '91 Chevy 1500
My Dad removed the TBI in his 1-ton truck about 15 years ago for a carb. Same pump, capped the return line and uses a returnless regulator (which EVERYONE says you are not supposed to do. Never had a problem. It only leaves the garage when he's towing a trailer, but he's got more than 100K on it since the swap.
I'm sure it's a fluke, so I did my swap with a return regulator just to be safe.
If you are using a return style regulator, it shouldn't affect the life of the pump at all since the pump doesn't see that it's any different than the TBI.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
TreDeClaw
Aug 14, 2015 06:58 PM
mcquigg
Aug 13, 2015 02:26 PM
92camaroJoe
Aug 13, 2015 06:07 AM
armybyrd
Aug 10, 2015 09:23 PM
