Good timing for a Carbed motor?
Car: 1992 Firebird
Transmission: 700R4 with B&M shift kit
Axle/Gears: 3.23 zexel 4th gen
I recently did a cylinder head swap on one of my cars and was wondering what a good initial timing would be. It's got an Edelbrock 600 carb and intake, and from what I understand it has a mild cam in it too. I'm not sure what the compression ratio is because the guy just said it had 11:1 pistons. I do know this though, the heads that are on there now are 75cc with 1.94" intake and 1.5" exhaust and when I saw the pistons they were domed and had 030 written on them. Thanks.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Good timing for a Carbed motor?
You mean 36* total timing, right? As far a setting base timing, most start at 10 - 15* BTD and adjust from there - think I'm running about 15.
Car: 84 trans am
Engine: 305 carb
my car is running around 12 degrees fine but she sounds real nice when i put it at stock 4. i have a edelbrock carb and intake 305 motor stock and a vacume advance distributor. were should i set for best fuel ecomemy not performace?
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
