Altenator wire question after tpi swap
Car: camaro iroc-z
Engine: 355 L98 Corvette engine
Axle/Gears: 3.27 9 bolt borg warner
hello all
i have a question about the 3 wire altenator!
it has 3 wires
S F L P
S: Red ( to constant 12v)
F: Tan/White ( go from 1 wire to 2 wires to the fan relay and plug)
L: Brown ( ignition 12v)
P: xxxxx
so now i have splice the hole ecm wiring
and now there is one wire left from the altenator and that`s the Tan/White wire thats come from the altenator!
what must i do with this wire?
must or can i use it for anything?
or is it like a 2 wire plug altenator now?because i don`t have the tpi anymore.
Dennis
it has 3 wires
S F L P
P: xxxxx
Dennis
Car: 1988 rs
Engine: 555BBC; Dart, Lunati, SRP, Howards
Transmission: ATI TH-400
Axle/Gears: 35 spline 9", locker, 3.00's
Re: Altenator wire question after tpi swap
the tan/white wire is the regulator turn on switch. that wire needs to get power from the ignition, or your alternator won't pump out any juice.
Car: camaro iroc-z
thanks ,but are you sure?
beacause i know the brown wire comes from the ignition to power the altenator!
i tought firts that the tan/white wire a sort off power wire was for the fans!
but oke i will believe you!
so i can hing that wire together on the brown wire?
dennis
dennis
