i HAVE NO FANS WORKING AFTER TPI TO CARB SWAP
Old Oct 20, 2009 | 02:59 PM
irocdaddy's Avatar
Car: 89 iroc,2012 eco 150,roadglide
Engine: zz4
Transmission: t56
Hey everyone-
I am in the middle of a carb swap from tpi on my 89 iroc.
I am keeping the ecm in the car since it seems to control a lot more than just tpi stuff.
I am unclear how my fans will work in this swap. The fan switch in the rt side head controls when the secondary fan comes on true? does the cts control when the primary fan comes on?
If the above is correct, does this mean the ecm is controlling both of these functions?
At what temps should the fans be coming on in a carb set up?
Old Oct 20, 2009 | 03:03 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
Re: i HAVE NO FANS WORKING AFTER TPI TO CARB SWAP
yes the cts controlls when the fans turn on. and if you only swapped the tpi setup for carb on the same engine, then the operating temps should be the same.
Old Oct 21, 2009 | 11:16 AM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
All wrong. The passenger side head has a sensor in the back between the 7 and 8 cyl. that controls one fan. When AC is turned on, once a certain pressure builds up in the line, the second one comes on. All the CTS does is tell the ECM how cold the engine is at startup so it can determine whether or not to use the cold start injector or, if the car don't have one of those, to hold open the #1 injector a hair longer for cold starts.
My suggestion is to rip out the ECM and wire in a switch to the dash so you can turn the fans on or off. If you have an auto tranny, you'll also need to figure that out for the TCC lockup, which I don't know much about since my car is a 5 speed.
Old Oct 21, 2009 | 02:59 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by IROCZ28KevinZ
All the CTS does is tell the ECM how cold the engine is at startup so it can determine whether or not to use the cold start injector or, if the car don't have one of those, to hold open the #1 injector a hair longer for cold starts....
No, the CTS works in conjunction with your IAC counts. Fuel prime happens with or w/out it, and the fuel pump is triggered when a certain RPM is realized....
Old Oct 21, 2009 | 03:52 PM
s10irocspikes's Avatar
Car: 86 IROC
Engine: 350 Miniram
I use this and works great. You'll have to run a 180' t-stat.
http://www.summitracing.com/parts/DER-16738/
If not, this works good too. Just watch the temp gauge after the t-stat opens and set the fan to turn on at desired temp.
http://www.summitracing.com/parts/DER-16759/
Good luck.
Old Oct 22, 2009 | 05:12 PM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
I went with a Hayden fan switch..
thanks everyone.
have to wait till it comes in the mail from amazon..
Old Oct 30, 2009 | 08:39 AM
92z28camarokid's Avatar
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
What I am going to do with mine is wire it up so both fans come on when I turn on the car. This will I hope keep the operating temp much lower by having both fans running at the same time rather then just one. Plus it should save me money on a switch.
Old Nov 1, 2009 | 01:19 PM
SpeedMetalT/A's Avatar
Car: 87 Trans Am
Engine: L98 350 w/carb
Transmission: TH350
Good choice on the fan switch and I would keep the ecm in the car with everything else hooked up no point in messing with anything else. If you do need a way to lock up your torque converter for your overdrive there are a few kits offered to control your tcc solenoid with a switch. http://www.jegs.com/i/TCI/890/376601/10002/-1
Old Nov 1, 2009 | 07:55 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Yes it will save you money on a fan switch, but in the long run it will cost you money on fan motors since they arn't designed to be run all the time, it will cut their lives short. It will also take your car longer to reach operation temp, especially in the winter. That being said that is how I set the fans up on my last carb swap, it worked just fine, I did however replace the fan motor (single fan setup) a couple times.
Old Nov 4, 2009 | 09:09 AM
Axle/Gears: stock
Do you think it would be a better idea to run the fans on a toggle switch then? I just dont want to take the risk of accidently leaving them on if I was in a hurry to get out of my car. Maybe I could wire them up so they would only have power when the car was on. What do you think?
Old Nov 4, 2009 | 09:22 AM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
I don't reccomend it. but what i did was Ground the relay switch so when i turn the car on to accel. it turns the fan on continuous circuit until i shut the car off. Only had to replace the fan once. Because it was orginal and the bearings went out on the other one. But doing this the relay switch will fry before anything else. I had to change 2 of those in the lifetime. I did toggle switches on cars and I forgot to turn them off and few hrs later. DEAD battery. So i decided to do that. Not ethical by all means. but it works and been working for 2 years.
Old Nov 4, 2009 | 09:23 AM
berlin305's Avatar
As that is noted I will be setting one up soon with toggle switch that when no power the toggle switch won't work on or off. and once i turn the Key over it will put power to the toggle switch so if i forgot to leave it on it would shut off anyways after i turn the key off.
Old Nov 20, 2009 | 06:16 PM
Awesome-X's Avatar
Car: 87 Camaro
I would think there would be an aftermarket switch of some kind that you could wire up, that would screw into a coolant sensor hole or something that could kick the fans on and off. Does anyone know of one? And also about the TCC lockout switch from jegs that was posted, how would you install that? I really need to get one.
Old Feb 21, 2011 | 04:13 PM
MSRed91Camaro's Avatar
Car: I have a 91 Camaro RS
Engine: 383 stroker
Transmission: Stock automatic 700r4
Axle/Gears: I have 3.73 Gears with a Eaton posi
saving info
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
jharrison5
Aug 19, 2015 05:53 PM
86IROC112
Aug 17, 2015 02:00 PM
