2 fuel lines
2 fuel lines
ok guys now im super confused i have a 91 camaro rs and i went to hook up my fuel lines to my holley carb and the lines are 2 different sizes ? does any one know what those sizes are?
Re: 2 fuel lines
ok well ive been really searching hard and i found out that one is a feed line and one is a return line. now i just need to know the sizes of the lines.... still searching, open to any help thank you.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 2 fuel lines
I hope you know that you cannot simply "hook up" either of these lines to your carb!
You MUST get a RETURN-STYLE fuel pressure regulator and put it between the lines and the carb! There is no other way. And ONLY a return-style regulator will work - if you see ANY regulator that sells for less than $80, it is NOT return-style and will not work.
You are looking for the Mallory 4309 regulator, or equivalent.
Your in-tank fuel pump on your 1991 car produces WAY too much pressure for a carb, and since the car has a return style fuel system, you have to use a return style regulator.
Car: 1992 RS
Engine: Carbed 350
Re: 2 fuel lines
There could be any number of things.
Did you change over to an HEI vacuum advanced distributor?
Get the firing order correct?
Check the plug wires for continuity?
What's timing set at?
Is this a motor swap, or just changing over to carb?
What motor do we have? What size carb?
Before we get it started and drive all over the neighborhood and fry the tranny - is this an automatic? If it is ...
Did you install the proper geometry corrector for the TV cable?
Did you adjust the TV cable properly?
Need lots more information...
Car: 1989 Camaro
Engine: 355
Axle/Gears: 9 bolt 3.45
theshackle
Mar 5, 2017 06:37 PM
ambainb
Apr 25, 2016 09:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
