700R4 kickdown and tv cable corrector...
I have a edelbrock 600cfm manual choke on a 355 in my 86 iroc z, I see they have the bowtie overdrives kickdown cable assembly, they also make tv cable corrector brackets... And as far as tcc control I want a kit that includes all new transmission wireing and solenoids. What do I need to buy to have relaible transmission control.
And yes I have read through the sticky a bunch. I just don't understand all of the information in it very well. Help is much appreciated! Thanks!
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 700R4 kickdown and tv cable corrector...
This is the lockup kit I used:
http://www.summitracing.com/parts/TCI-376600/
and I used this bracket for throttle cable/TV cable 'cause it was hefty, chrome, and stronger than the Spectre crapola:
http://www.summitracing.com/parts/EDL-8030/
And this is the geometry corrector:
http://www.summitracing.com/parts/SUM-700203/
Car: 1986 Camaro Z28
Engine: 305 Carb
Car: 1992 RS
Engine: Carbed 350
It was easy - just a pain since the tranny pan has to come off - but I had my tranny out for a rebuild at the time, so wasn't a big deal for me. Just be very careful with the little vacuum switch they provide - I broke off the hose nipple on install - that's the only bad thing about this kit - small junky vacuum switch.
There is a kit available now that doesn't require removal of the tranny pan - it uses your existing internal parts - just changes wiring harness - it uses the VSS on the tailshaft to get speed input, and you can adjust at what speed the TC locks up - it might be the B&M kit, I don't remember - I do remember it was like $160 as opposed to the $90 most the others are - but well worth it given that you don't have to remove the pan!
Engine: 305 Carb
Dragonsys
Sep 25, 2015 03:51 PM
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
305, 700r4, 90, adjustment, cable, camaro, carb, carbureted, control, engine, engines, installing, kits, order, transmission, tv
