is it just me or does edelbrock suck? looking for a new carb.
Old Nov 17, 2009 | 04:33 PM
Jammin'Trey's Avatar
Hey guys I have a edelbrock 1406 600cfm manual choke carb right now, I have had hell trying to keep my freshly rebuilt 350 running, (crnk turned .010, bored .030, 9.0:1 @ 72cc pistons, timing chain, all new gaskets, mech edelbrock fuel pump, carb gas tank line modification)
This is on a 1978 chevy 350 out of a truck, It has 883 heads with new valves and seats, performer RPM intake, 700r4 (lockup and tv corector bracket).
The car is a 1986 Iroc-Z,
I plan on putting in a set of edelbrock performer rpm 64cc heads, and a thumper cam (279/297 .498,.483).
This car will be daily driven in the summer, I hope for 325 rwhp. Or around that.... The cam in the car right now is a summit 262/272 .420.442...
This car will be daily driven in the summer, it sits in a heated garage in the winter, I will drive it some in the spring so electric choke is a must for me.
Old Nov 17, 2009 | 04:47 PM
Shadow Z's Avatar
Car: Lots of 'em
Re: is it just me or does edelbrock suck? looking for a new carb.
What is the point of this? To get advice, some tech help, or argue about different brands? Sure, Edelbrock isn't the best product around, but you get what you pay for.
I know for a fact most guys here would LOVE to go sink over ten THOUSAND dollars into a Hogan's Sheet Metal Intake, a complete FAST EFI fuel injection kit suitable for up to 1,000 horsepower engines, which is $4,000+ alone. Then top it off with some very pricey Brodix Track 1 heads, but hardly anyone here could afford that, so we stick with cheaper parts that'll make for a reliable daily driver for up to 500 horsepower engines.
Anyone else that replies will most likely say the same as I did, you get what you pay for, especially with Edelbrock, they're well performing parts for the price.
Old Nov 17, 2009 | 04:53 PM
was wondering on carb suggestions, I am looking to get away from edelbrock, I might look into one of their avs series because I have an auto trans. But I have been looking into street demon and holly carbs, everyone seems to like the double pumper series.
Old Nov 17, 2009 | 05:35 PM
danandamy's Avatar
Car: 86 Camaro
If you're looking to get away from Edelbrock than I'd get away from them. I've run the Holley Street Avengers on several of my rigs and I've got absolutely no complaints. I did have to rejet it a little bigger but that was easy enough. The easy adjust secondary spring set up is cool too.
Dan
Old Nov 17, 2009 | 10:44 PM
looks to be a very appealing carb, I did some research tonight, I think im going to buy a new carb for the first time, I think I always am getting some second hand messed with carb... I am going to order a edelbrock thunder avs electric choke. Thanks for the input guys. /thread
Old Nov 18, 2009 | 07:36 AM
Adrenaline91RS's Avatar
Car: 1991 Chevy Camaro RS
Engine: 350 Crate Motor
Axle/Gears: 9-bolt Limited Slip
yep i got a edelbrock carb to and i hate the thing
Old Nov 18, 2009 | 08:51 AM
da.slyboy's Avatar
Car: 84 frankenstein Z28
So you wanted advice on what carb besides an edelbrock to purchase, then you decided on another edelbrock?
Old Nov 18, 2009 | 12:13 PM
EvilCartman's Avatar
Car: '82 Z28
Holley or Demon are going to be a better choice. Don't go with the Road Demon though, their choke linkage is goofy and can sometimes get in the way of the air cleaner. Whatever brand you get, check over the carb really well for problems.
Old Nov 18, 2009 | 06:23 PM
radical82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
If someone in the past has the jetting and metering rods all messed up, that's probably not Edelbrock's fault!!!! I've installed Edelbrock carbs on a number of cars, when set up and calibrated per the Edelbrock instructions, they work great!!!! Holley's are the same way, if somebody previously has installed a bunch of wrong parts, they aren't going to work right either!!!
Old Nov 19, 2009 | 10:15 AM
pajama sam's Avatar
jetted my edelbrock 750 so many times and just couldnt get it right. Droped a holley 670 street avenger on and it runs like a top. just my experience
Old Nov 20, 2009 | 05:43 PM
Awesome-X's Avatar
Car: 87 Camaro
If you wanna sell that 1406 let me know I might buy it off you! I like my 1406 and I wouldnt mind having another.
Old Nov 25, 2009 | 01:26 PM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
i have a 1405 on my 350 and it's fine.
Old Jun 5, 2010 | 10:19 AM
2fast4utaz's Avatar
Car: 1985 camaro z/28
Transmission: 700r4 stage 2
Axle/Gears: stock for now
i had an edelbrock carb i bought it brand new i have had problems with it form day one. my wife went out and got me a holly ultra lite 670 cfm no problems out of box and on to car
Old Jul 2, 2010 | 06:18 PM
game1939's Avatar
Car: 91 chevy camaro
Engine: 383
Transmission: 700r4 built with corvette servo
Axle/Gears: posi 3:73
have 455 plus horsepower 383 with an edelbroeck 1406, no problems had holley on it before will never go back......
Old Jul 2, 2010 | 06:37 PM
mooch1's Avatar
Transmission: T5 WC
i had a holley ,,,and didn't like it..put on a 1405 edelbrock 2 years ago and it never ran better,,,this spring i have had idling issues,,,but i was on low gas and i'm sure i blocked something ..cleaned it out and it seems much better,,,,i will never go back to holley ...q-jet yes ..and edelbrock yes...
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
3.8TransAM
Oct 1, 2015 07:47 PM
Night rider327
Sep 25, 2015 04:47 AM
