eldelbrock idle?
Car: 84 trans am
Engine: 305 carb
eldelbrock idle?
Cant get my car to idle below 1000rpm and i have the idel set scew all the way back till it stops touching the throttle? any help on this will be great THANKS
Car: 84 trans am
Engine: 305 carb
Re: eldelbrock idel?
I'm sorry, this is with my base timing and vacum advance disconncted. with it connected the idle is at 1500-1600rpm and this is as low as it will go???
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
Throttle cable length is wrong not letting the carb shut all the way down to idle.....
Car: 84 trans am
Engine: 305 carb
I done this with the throttle cable off but i just noticed that when i spray carb cleaner around the throttle linkage were it goes in to the carb she will stall. it must be sucking air around there. what can i do to fix this?
Car: '82 Camaro
Engine: 383
If it's the throttle shaft itself leaking you'll need to order up the bushing's and throttle shaft (if the shaft is worn, too) from Edelbrock.....
Car: 84 trans am
Engine: 305 carb
would this be my idleing issue? that air is leaking around the shaft and causeing the car to idle faster? and is this normal for these carbs? THANKS
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: 1985 trans am
Engine: 1969 chevy 350 .060 over
Transmission: 5spd
well, my car was having a miss at low rpm, so one day when adjusting the air/fuel mixture, i decided to kick it up a notch on the idle speed screw.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
With that said, after looking at your profile, I realize I got my first fbody years before you were born, so I imagine you are still learning.
-- Joe
Car: 1985 trans am
Transmission: 5spd
this is the first car I have worked on, and I am quite proud of myself, with the amount of things I can now say that I have done to a car
