REMOTE START FOR CARB
Old Dec 23, 2009 | 08:09 PM
charlietransam's Avatar
Car: 1984 Trans am
Engine: V8
So im searching the internet for alarm systems and i come across a website that says somthing about a carb kit used for a remote start alarm. is there such a thing and where can i buy one? or is thie guy full of $#!+
http://en.allexperts.com/q/Car-Alarm...Start-Carb.htm
Old Dec 23, 2009 | 08:46 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: REMOTE START FOR CARB
I'm not sure why regular remote start systems don't work with carb. I have a remote start on my Trans Am and the only thing FI specific I can think of is the tach signal, but even then, I'm pretty sure its the same with a computer controlled carb...maybe its the number for turn overs?
Old Dec 23, 2009 | 09:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If it opens the throttle enough to set the choke before trying to start the car, it could work.
Old Dec 23, 2009 | 09:52 PM
one92rs's Avatar
Car: SOLD!!!!!
well a pump is not what you need. you need it to energize the pump you have if it is electrical. what you would need is a solenoid similar to an a/c signal one to idle the carb up. that would set the throttle to choke. if it was able to throw it back enough and not cause to high an idle.
Old Dec 24, 2009 | 11:35 PM
Pre-Tuner's Avatar
Car: '91 Chevy 1500
I install remote starts for side money and I have never heard of it. Doesn't mean it doesn't exist though.
I installed a remote start on my TBI, then recently swapped to a carb set up. The remote start is still installed, but it will not start unless I tap the throttle first to set the choke. It just keeps cranking.
The tach signal is still there because it is off of the coil, not the ECM. If you have a remote start connected with a tach signal, the remote start uses it to know when to stop cranking. Alternatively, you can set the remote start to a specific time to crank for (without using the tach wire), but if it doesn't start after that time, it doesn't start.
Old Jun 5, 2010 | 12:04 PM
RaGiN Z's Avatar
Car: 83 Camaro
Engine: 383 stroker, mini blower, nitrous
Transmission: TKO600
back from the dead!
I have been thinking about this, I have a remote start in my basement. I was going to get a trunk popping solenoid and tie that into a throttle cable and attach that to the linkage of carb. Press the trunk button a couple times and it primes the system. Hot wire the clutch depression indicator, press the start button, good to go.
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
cstrobel65
Aug 15, 2015 10:19 AM
