what size carb to get???
Car: 88 Iroc
Engine: 383
Axle/Gears: 3.43
99% street driven car!
383 Stroker
Flat top Pistons
I-Beam Rods
TrickFlow Heads 195's, 64cc Chamber 2.02/1.6 Valves
1.6 Rockers, Full Roller
Comp Cams XE284H RPM range 2300 to 6500.
240/246 Duration @ .050 .507/510 Lift w/ 110 LSA
Intake is a Torqer RPM from Eddelbrock
383 Stroker
Flat top Pistons
I-Beam Rods
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Re: what size carb to get???
quick fuel 650 cfm or holley 700-750 cfm ........
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
Pro System Carbs can make a custom holley carb spec'd for your engine combination. Bolt it on, set the idle, and go.. He set my 396 up with a 780cfm piece and it's awesome. Idles all day and runs 140mph at the track with the nitrous flowing..
Quote form: http://www.prosystemsracing.com/quote.html
homepage: http://www.pro-system.com/
There's none better... Mine was cheaper than a box stock piece out of a jegs catalog I believe... money well spent.
Car: 1996 jeep cherokee
Engine: 4.0
Transmission: 4 speed auto
Axle/Gears: chrysler 8 3/4 3.08 gears
If you have the money get a predator, they have adjustable cfm's so you can run it on your motor now. But if you decide to do more work or a forced induction system you can bring it up some.
Billy Decker
Sep 4, 2015 03:46 PM
GeneralIesrussi
Sep 3, 2015 03:23 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
