Diff between carb vacuum and intake vacuum?
Old Jan 27, 2010 | 08:55 AM
CobraEatr's Avatar
Is there a difference? I'm a carb newbie and I'm trying to reconnect all my vacuum lines. Here's the setup I'm going to go with, please correct me if this is wrong.
Distributor - Carb Vacuum
PCV - Carb Vacuum
Brake Booster - Intake Vacuum
Transmission Vac - Intake Vacuum
Thanks in advance guys.
Old Jan 27, 2010 | 08:59 AM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
Re: Diff between carb vacuum and intake vacuum?
I use the lower carb vac for the trans. If I had dizzy vac I would run that on the upper carb vac(ported). The other two are fine IMO. I'm refering to Holley, Not sure about Q jet.
Mark.
Old Jan 28, 2010 | 01:06 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
To be more specific:
Carb "timed" or "ported" vacuum - above the throttle plates, therefore no vacuum until throttle opened above idle.
Carb "full" vacuum - below the throttle plates, therefore same vacuum as the intake plenum. Usually from one venturi only.
Carb "plate" vacuum - usually a larger port in the throttle plate, between primary or secondary venturi.
Manifold plenum vacuum - below the carburetor, in the plenum and therefore fed by all cylinders.
Manifold runner vacuum - on a particular cylinder's vacuum, therefore not fully fed by all cylinders.
"Timed" vacuum was used primarily for emissions control, such as vacuum advance, EGR valve, etc.
"Full" vacuum was the pre-emissions hook-up for vacuum advance.
"Plate" vacuum usually used for a vacuum device that has a small amount of flow, like the PCV valve. Used by the factory on q-jets for the brake vacuum power booster.
"Plenum" vacuum rarely used by the factory, sometimes used as a replacement for plate vacuum when a carb doesn't have that port available.
"Runner" vacuum used for non-flow devices like transmission vacuum modulator, HVAC control, etc.
Infested
May 22, 2018 11:56 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
86IROC112
Aug 17, 2015 02:00 PM
cstrobel65
Aug 15, 2015 10:19 AM
