Got an odball combination of code
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
My SES light came on and got codes 13, 21, & 44. So with code 44 I am apparently running lean which could be from the code 21 TPS sensor and code 13 I am guessing was tripped by codes 21 & 44. Anyone else get these same codes at the same time before?
Transmission: 4L80E/4L80E
Can't say I've gotten that combo nor do I recall hearing anyone who has, but lean O2 is almost always caused by a weak O2 sensor.
Check what your TPS voltage is doing.
Car: 1987 Camaro LT
Re: Got an odball combination of code
Yea, been reading on here about the voltage issue. Going to buy a volt meter this weekend to check. As far as the O2 sensor, it's not even a year old Walker unit. I may have to go back to the stock type.
darwinprice
17
Oct 11, 2015 11:51 PM
