tpi to carb...what throttle cable?
I got a 87 iroc and going tpi to holley carb hp 650 series. what throttle cable are you using. my original one is bout half inch too short. I got the holley bracket to hold the tv cable and throttle cable.
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
The factory '82-'87 carb'd 3rd gen cable should work.
People have said the '88-'92 TBI cable also works.
If you go with a Lokar, you know it'll be right because you'll cut it to fit.
Car: 1991 Formula
Re: tpi to carb...what throttle cable?
You want to sell the Accell Superram set up.I will give you $1400 for the intake set up with throttle body,injectors,rails,chip,distributor.I met you at the plainfield car show last year(red 91 formula) That was a nice set up why you going carb??
9192camaro
16
Feb 3, 2019 12:21 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
