sending unit pics
Old Feb 19, 2010 | 07:20 PM
Sutton's Avatar
Car: 82' Trans Am
Engine: 383
Transmission: t-56
Axle/Gears: 3:73
sending unit pics
I have an 82 TA. I pulled my sending unit out of my tank tonight. I have 4 line coming from it. I know the one line is a vent, one is the fuel feed, and the other two go up to the charcoal canister. My question is can I get rid of lines going to the canister. I want to remove that whole system if I can. I am just not sure what it does. I will be installing a LT1 motor in a few months.
Attached Thumbnails sending unit pics-1.jpg   sending unit pics-2.jpg   sending unit pics-3.jpg
Old Feb 19, 2010 | 10:02 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Re: sending unit pics
Actually, 2 lines go to the fuel pump, and one line goes to the vent valve, and one goes to the canister. I don't think you can plug the canister line. I think the tank may collapse if you do. You can probably put a vent over the end of the line.
Old Feb 20, 2010 | 08:07 AM
Sutton's Avatar
Car: 82' Trans Am
Engine: 383
Transmission: t-56
Axle/Gears: 3:73
But the whole canister system can be removed right?
Then just install a vent on the end of the lines.
Old Feb 20, 2010 | 08:47 AM
Drew's Avatar
Sure, if you don't mind the stench of gas fumes.
Old Feb 20, 2010 | 12:52 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Not legally!
Old Feb 22, 2010 | 07:00 AM
Sutton's Avatar
Car: 82' Trans Am
Engine: 383
Transmission: t-56
Axle/Gears: 3:73
How would this be any different than the other vent coming from the tank?
I assumed allot of people did away with these in there cars?
86CamaroDan
Sep 29, 2015 10:08 PM
Gunsbee
Sep 7, 2015 07:10 PM
TheExaminer
Sep 6, 2015 11:40 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
