Charcoal can questions
Old Mar 14, 2010 | 12:30 AM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
I converted from TBi to carb, and currently the charcoal can is still in place and plugged into the tank line.
The vacuum line is currently capped off, but the tank line (as previously stated) is still connected. I'd like to know if this will cause problems like in-tank pressure and whether or not I can alleviate it with a vented gas cap.
Thanks in advance, J.
Old Mar 14, 2010 | 04:32 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Charcoal can questions
I removed mine altogether - I just ran a fuel hose fro the third fuel line to out under the car to prevent any possible fumes or liquid leaks from happening in the engine bay where there are hot things. No pressure problems with mine - can't remember if I ever replaced the gas cap or not though.
I replaced with a coolant overflo/washer resevoir tank from a Ford Explorer - matches the size of the battery on the other side (symetrical), looks good, and got rid of those huge (now yellow and dirty) jugs on each fender.
Old Mar 15, 2010 | 07:26 AM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 10 bolt Richmond 3.73 posi w/ discs
Is the purge valve still connected? If so you'll have problems, otherwise you shouldn't.
Casey Meyers
Mar 2, 2016 10:46 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
redmaroz
Aug 16, 2015 11:40 PM
BurlyChev
Aug 16, 2015 09:08 PM
Mister_Johnny99
Interior Parts Wanted
Aug 14, 2015 12:59 PM
