650 dp
Old Mar 22, 2010 | 03:59 PM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
650 dp
I want to use this carb on my 383 .
http://www.jegs.com/i/Holley/510/0-4...oductId=746470
how hard would this be to get set up?
thanks , Tyler
Old Mar 22, 2010 | 07:05 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Compared to what? Solving world hunger? Easy!
Would be nice to know what you have, what you are intending, and what you'll be using the final product for.
Old Mar 23, 2010 | 12:40 AM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
Re: 650 dp
lol , im sorry .
Heads : Procomp http://www.jegs.com/i/Procomp-Electr...oductId=957641
Cam : 280h
About 10.5 : 1 compression ratio
Its going to be put in a daily driver
Old Mar 23, 2010 | 12:44 AM
84z .....'s Avatar
Car: Blue 84 z28/Cyber 2010ss/rs
Engine: Dart headed, 12:1 355- 510/530 cam
Transmission: TKO 600 Lakewood Bell
Axle/Gears: Richmond 410 Spooled
Re: 650 dp
this carb comes set up pretty well, u mit just have to change the jets
Old Mar 23, 2010 | 07:34 AM
five7kid's Avatar
What intake manifold?
I'd add an electric choke kit for a daily driver.
Plan on needing to tune it, both the initial set-up (float levels, idle speed and mixture) and jetting.
Old Mar 23, 2010 | 10:09 AM
tyler92's Avatar
Car: 91 Camaro RS
Engine: 5.3
Transmission: Th400
Re: 650 dp
Sorry i forgot to say . Performer RPM.
I have experience at intial setup of a carb
But i have never changed jets , roughly what jets do you think i should be using ?
Old Mar 23, 2010 | 11:21 AM
five7kid's Avatar
I'd start with what it comes with, see how it does. Typically go in 2 jet size increments up or down to get to the final sweet spot.
The Holley jet assortment kit is an easy way to have the jet sizes you're going to need (probably ever), won't cost more than a few jet changes if you bought the jets in pairs.
ZZ3Astro
Aug 13, 2019 12:57 AM
bbsr72
Apr 2, 2016 09:12 AM
beastin91rs
Oct 9, 2015 07:38 AM
Chad Speier
Sep 24, 2015 12:32 PM
buckshot63
Sep 10, 2015 09:15 AM
