Holley idle not going low enough
Old Mar 25, 2010 | 09:39 PM
mos68x's Avatar
Car: 1991 Camaro RS/Z28
Engine: 357 Edelbrock Intake & Holley Carb
Transmission: WC T-5
Axle/Gears: whatever stock is
Been working on this new carb and for the life of me I can't get this carb to drop in idle properly.
The only way that I've gotten the idle to drop enough is to back the secondary idle screw as far off as it will go without totally disengaging the secondary. The primary idle screw is backed all the way off with a large gap, I can put pressure on the throttle to get it to drop and it will go lower but will come back up. It is also causing a problem with the transfer slot and a lean spot there during acceleration.
Also can't get the high idle to drop down to the 1500, it's staying up at 2500-3000. I've backed the high idle off as far as it will go to where it doesn't make screw isn't exposed through the plastic nut.
With the throttle not backing down I checked the throttle cable and even with it disconnected the carb still does this and the only place that I can see that could be the problem is right behind the throttle linkage real close to where the cam for the accelerator pump makes contact with the throttle linkage. I can try to take pictures but I need to find my camera's battery charger first.
Old Mar 25, 2010 | 09:41 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: Holley idle not going low enough
does it have a choke?
Old Mar 25, 2010 | 09:46 PM
mos68x's Avatar
Electric
Old Mar 25, 2010 | 09:51 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
so are there any holes in the throttle plates? if not there must be a vacuum leak somewhere.
Old Mar 25, 2010 | 10:00 PM
mos68x's Avatar
No vacuum leaks, I've double and triple checked for that. Plugged all ports with no improvements, double checked all gaskets and there are no high uncompressed areas.
Old Mar 25, 2010 | 10:03 PM
then there must be something binding in the linkage maybe a bent throttle shaft.
Old Mar 25, 2010 | 10:08 PM
mos68x's Avatar
This thing is brand new, never been used before. I'm sure that it has to be a problem with a screw that I haven't adjusted yet. Maybe even a cam that I might need to change.
Old Mar 25, 2010 | 10:24 PM
there is only the primary and secondary idle adjustment. if something else is wrong i would send the carb back. have you called holley?
Old Mar 25, 2010 | 10:25 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
What about your timing, do the installation instructions say anything about adjusting the timing?
Old Mar 25, 2010 | 10:38 PM
GXR11's Avatar
Car: 91 C1500, 84 Camaro, 87 monteSS
Engine: 4.3L,Gen1 350. 391ci & 383 LS1
Transmission: t-5,man vavle body 700r4, no trans
Axle/Gears: 3:73, 3:42, 4:10
is this a new/fresh motor? or one that was running fine before the new carb?
holley spends enough money in thier R&D that just bolting it on right outta the box should yeild better results then it sounds like your getting
see if some one will lend you a carb that you know works fine... after bolting it on and everything seems to be ok (minus minor adjustments) take that junk and return it for another one... if there is still an issue, well, my friend, find that vac. leak.
Old Mar 26, 2010 | 06:12 AM
mos68x's Avatar
Timing is set at 14* base.
The motor was running at idle better than this when I had the Edelbrock on it.
Haven't called Holley yet, this here was my final resort before calling them.
Old Mar 26, 2010 | 11:02 AM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 10 bolt Richmond 3.73 posi w/ discs
Check the secondary throttle adjustment, that would cause it.
Old Mar 26, 2010 | 11:36 AM
mos68x's Avatar
I already have it backed off as far as it will go and if I turn the screw to open the sec's then it just makes the idle even higher.
perZ
Aug 21, 2015 05:51 PM
Dialed_In
Aug 20, 2015 01:45 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86IROC112
Aug 17, 2015 02:00 PM
perZ
Aug 15, 2015 01:17 PM
