Holley carb probs! need Help!
Old Apr 6, 2010 | 07:27 PM
schmeck11's Avatar
Car: 82 TA
Engine: 305 swap 350 swap 383
Transmission: 2004r
Axle/Gears: 3:73
problem is the rpm hangs for awhile. for instance when turning a corner at slow speed and giving a little gas and letting off, the rpm hangs at 2000 and keeps going for a period of time and then idles down. or on freeway in OD I will let off and it will act as if cruise control was on and keep running at rougly 2000 rpm for a bit. carb is 2 years old and this just started last fall. all linkage is working correctly. seems as if something is sticking, but not sure where to start or what to look for. thansk dan
Old Apr 6, 2010 | 07:49 PM
huffediroc's Avatar
Car: 87 iroc
Engine: 350 with weiand 144
Transmission: tremec TKO 600,mcleod street twin
Axle/Gears: strange s60
Re: Holley carb probs! need Help!
try putting a stiffer retracter spring on the throddle
Old Apr 6, 2010 | 08:10 PM
schmeck11's Avatar
Car: 82 TA
Transmission: 2004r
Axle/Gears: 3:73
but I never had this issue before, why would it start now? all linkage snaps back like new. ??
Old Apr 6, 2010 | 08:19 PM
huffediroc's Avatar
Car: 87 iroc
see if it hangs on the rpm in park too. make sure your giving it a steady flow of gas with the pedal and not from the carb by hand. (as though you are driving) if it still does it and you know your spring is good then something may be wrong with your pedal or linkage is loose
F.I. 57 Belair
Aug 23, 2021 01:09 AM
customblackbird
Oct 1, 2015 04:30 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
makaveli09
Sep 15, 2015 10:43 AM
WickedBowtie
Sep 11, 2015 11:24 PM
