CC Quadrajet Lean on Cold Start
Old Apr 12, 2010 | 08:32 PM
trumps2000's Avatar
Car: 1985 Z28
Transmission: T-5 5 Spd
Axle/Gears: Built 10bolt w/3.73s
Since I installed my WBO2 I found out that the car runs lean on cold starts. I thought rebuilding the carb might fix it, but no luck. The next thing I'm going to try is plugging all of the vaccuum lines. Anyone have an ideas of what I should look into?
Old Apr 12, 2010 | 09:16 PM
bcmag's Avatar
Re: CC Quadrajet Lean on Cold Start
does it run poorly cold or your just noticing its lean?check pulloff maybe opening choke plate too far?
Old Apr 13, 2010 | 08:38 AM
trumps2000's Avatar
Car: 1985 Z28
Well I'm just noticing it running way lean at startup, but I think it could a little better cold.
Old Apr 13, 2010 | 11:11 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Until it goes to closed loop, the computer carb operates on a preprogrammed basis which assumed certain things from the factory build, such as engine displacement, cam, exhaust, carb primary jets, etc. Since you have increased the displacement of the engine and changed the cam, the preprogrammed assumptions will be off. Not too surprising that it's a little lean. You can decrease the amount the vacuum break (choke pull-off) opens the choke butterfly at initial start-up, but that will be overcome when the choke thermostat opens the butterfly beyond that. I adjusted the pull-off by trial & error until it ran well when first started but still came off the first high idle step when the throttle was tapped.
A thermovac/heat riser/snorkel air cleaner would help it run a little better after starting (if you aren't running one now).
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
apie2546
Aug 10, 2015 05:43 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
