Low pressure air?
Old Apr 17, 2010 | 07:06 AM
383fbod's Avatar
Car: 88 IROC-Z
Engine: 383
Axle/Gears: 4th gen 3.42posi
Low pressure air?
Reposting
I have an IROC hood with the 2 openings in the rear of the lowered areas cut out. If I make an air box that isolates the carb from the engine bay and seals to the hood, will the air that passes over the hood cause a low pressure area and pull fuel OUT of the carb, or , act as a "ram air" hood? At least act as a cold air intake?
http://s808.photobucket.com/albums/z...rilpics059.jpg
Old Apr 17, 2010 | 08:29 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Low pressure air?
i think it will work well. i had fuel siphon out of my carb. i was drag racing with no hood or air filter.
Old Apr 18, 2010 | 07:04 PM
383fbod's Avatar
Car: 88 IROC-Z
Engine: 383
Did you go lean? What caused the fuel to siphon out, just the passing air over it?
I think Im gonna use this and call it a day.
http://www.jegs.com/i/K%26amp%3BN/599/66-1401/10002/-1
dcbsracing007
Aug 18, 2015 07:24 AM
BurlyChev
Aug 16, 2015 09:08 PM
jackhammer
Aug 15, 2015 10:04 PM
perZ
Aug 15, 2015 01:17 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
