Hesitation at WOT
Car: 1985 Firebird Trans Am.
Engine: 305 H.O. 4bbl
Transmission: 700R4.. I think
Axle/Gears: Not Sure, 3.73?
Hesitation at WOT
Ok, so recently I made a thread "New Carb Options" where I was looking for opinions on some new carbs where my factory Q-Jet wasnt running right. I was told from a few people to keep using the Q-Jet if possible, so, I found one that I had kicking around out in the garage and decided to slap it on and give it a whirl.
First things first, this carb runs much better then the one that I was using. However, there is a fairly big hesitation now at WOT, not so much when the car is in park but when the engine is under load in drive it is most noticeable.
I should tell you while I was at the car I did a compression test (lowest compression was 180 PSI highest was 190), checked/adjusted timing, checked spark plugs for excess carbon/proper gap, replaced fuel line after me being a dummie and kinked it off, adjusted the choke and mixture on the new carb, adjusted the idle, re-routed some vacuum lines to proper locations and replaced the thermostat. Oh and cut down the rear drums and adjusted the rear brake shoes, but I dont really think that is relevant in this post.
I have been told that where the carb has been sitting for about 5 years or so that the seals may be dried out and may need a tank of gas or two to moisten up, the hesitation dosnt seem quite as bad but its still really noticeable.
Any help would be greatly appreciated!
Trent
Trent
Re: Hesitation at WOT
haven't tried any of that, any idea how I would go about it?
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
Damon
Sep 26, 2015 04:29 PM
