M/C solenoid help
Old Apr 23, 2010 | 12:31 PM
PivaJr's Avatar
Car: 1984 Camaro Z28 H.O.
M/C solenoid help
SORRY GUYS I need your help...
I think on my '84 Z28 HO the M/C solenoid is gone!
I've done all the tests suggested by the shop manual... basically the ECM send the signals to the carburetor, it receives them (measured it with an oscilloscope), but it's not able to regulate the air/fuel mixture (infact it's always too rich).
Where can I find a new M/C solenoid?
I'm Italian, so I'm not able to find it here and I haven't been able to find it on the internet.
In the worse case, I was thinking of replace the carb and the distributor to get rid of the electronics...
Thanks!
Old Apr 24, 2010 | 03:01 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: M/C solenoid help
Doesn't mean the solenoid is bad. If you can hear it clicking when the key is turned to 'run' the MC solenoid is probably fine.
If it's far enough out of adjustment the ECM won't be able to go into Closed Loop and it won't be able to respond to O2 readings. Start with the basics:
Set your timing.
Check your TPS voltage, ensure that the voltage smoothly increases as the throttle is opened-this can be checked with key in 'run' engine off.
Adjust your Idle Air Bleed (IAB) per the shop manual until the readings show it beginning to respond to the mixture. Set the IAB when the MC dwell hovers around 50% at idle-when it's in Closed Loop the dwell will be constantly varying as it adjusts to the mixture.
If the above fails your carb may just need a rebuild-basically a thorough cleaning and new soft parts.
one internet source for parts is carbsunlimited.
Quzyle
Oct 15, 2015 03:35 PM
mcbitchman
Sep 30, 2015 01:00 PM
mcbitchman
Sep 29, 2015 12:32 AM
IROCZDAVE (88-L98)
Sep 22, 2015 02:22 PM
Racerx974
Sep 19, 2015 10:16 AM
