simplifying carb
Old May 14, 2010 | 11:09 PM
tylerv350's Avatar
Car: 1982 z28/rs... haha
Engine: 305(now) 333(soon)
Transmission: 350 3-speed automatic
Axle/Gears: 3.45 limited slip 10 bolt
simplifying carb
i got a stock 305 in my z28 and its a 2 barrel carb. it has so many vacuum hoses all over it and all i want to do is be able to take off that big air filter shell off so i can put a new filter on there and have it fully exposed. is there any way of doin that? and what vacuum hoses that can be removed? im not worried bout emmisions or loosin a little mpg's but i just want the engine to look better
Old May 17, 2010 | 11:15 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Are you sure about that? The only 3rd gen f-bodies that got 2 bbl carbs were V6's.
You can put an open element air cleaner on as long as it has a drop base. A better route would be to add another snorkel. https://www.thirdgen.org/dualsnorkel That doesn't eliminate any vacuum hoses, but it does work better than the stock single snorkel, or an open element.
You can reroute and clean up, but every vacuum hose has a function. The two easiest to remove are A.I.R. and EGR. Removal involves plugging up holes after removing parts, and is, of course, illegal in all 50 of the United States for vehicles operated on public roads.
Old May 17, 2010 | 08:13 PM
tylerv350's Avatar
Re: simplifying carb
it aint a stock engine for the car, somebody put a new engine up in there.
alright then, i will see about the snorkel and if i can get it done
haha, im guessin that would probably not be the best route
Old May 20, 2010 | 10:32 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
"removing" vacuum lines, in my experience, is usually more trouble than its worth.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
