Intank fuel pump clarity....
Old May 28, 2010 | 05:04 PM
oguin_studking's Avatar
Car: 1990 Firebird Formula
Engine: 358
Transmission: 700-r4
Just to get some clarity here. I've read several threads here and have seen people say "all you gotta do is keep the stock intank pump and put a regulator with a return on it". Then others say you have to drop the tank and do some other things. Others say put a inline pump and forget the intank one. Im confused; also im new here so "Hello to yall".
Old May 28, 2010 | 05:25 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: Intank fuel pump clarity....
Fuel supply systems range from mild to wild. Mine's on the wild end. Is there a problem with your's? What are you looking to do?
Old May 28, 2010 | 06:12 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
x2?
what are you looking to do, what engine did the car have, and whats going in? i assume you are going from TBI/TPI to carb? if that is the case, then just leave the tank alone and use a return style regulator to drop the pressure for the carb.
Old May 28, 2010 | 07:40 PM
Engine: 358
yup goin' from a 305 TPI to 358 sbc with a carb. im glad b/c i was wanting to add on to my exisiting fuel rails and just buy a regualtor. not goin too wild here im just trying to get a lil over 400hp. someone did say you would have to do something to the intank pump to use it for a carb. but i cant remember what & im not even sure you have to do that.
Old May 28, 2010 | 09:08 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Dont need to drop the tank if the in-tank pump is still functional.
Run a Mallory return style regulator, and, under the hood, run your feed, return, and a line to the carb with a pressure gauge closer to the carburetor, set the regulator at 5-6 psi and thats it.
Old May 29, 2010 | 02:32 PM
Engine: 358
F'in Awesome! Preciate you clearin' that up for me bradley!
Old May 29, 2010 | 03:05 PM
Haha, no problem.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
